MarkusAurileus
Hi, hope everyone is doing great. New to the forum and beginner in TVs. I've done some reading on 4K, and the basic "what to know" for buying a television. Also, I tried researching a clear answer before posting this, but fell short. Hopefully, I can get some clarification from this thread. Thanks in advance for any help you can offer!
Question:
When a TV spec shows 3840x2160 as its 4k resolution, is that the native resolution?
I ask this because I'm currently viewing on a 32" Sony Bravia FHD KDL-32L5000, with my HTPC putting out at native resolution of 1360x768. Although the TV is a "1080" HDTV, the image at this "768" resolution provides the best picture, looking notably crisp at a viewing distance of 4-6 ft. Side bar - haven't had any discernible issues with input lag.
I'm looking at getting a 43" LG 4K UHD TV, and I'm curious if 3840x2160 provides the best image, or if it simply "accepts" the image but has a different native resolution. Or should I just get a 43" HD TV?
Question:
