Native Res of Pio 50MXE1
Discussion in 'Plasma TVs' started by Twan1, Jan 27, 2005.
  1. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    Can someone explain what this means?????, i understood that this plasma can run at 50 & 60 HZ so i thought i wouldnt get any screen judder when watching region 1 NTSC discs??
    Any info or experiences would be great!
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    24,283
    The Borders
    +2,573
    Twan1
    The 'Native Resolution' of the PDP-50MXE1 is 1280x768 pixels.
    The Display accepts a wide range of line and refresh rates via its analogue and digital inputs - including various 50Hz and 60Hz signal formats.
    The Display has three Frame Rate Conversion (FRC) modes - you select which Mode to operate in via the Service menu.
    FRC Mode One actually carries out Frame rate Conversion on pretty much every signal you throw at the Display - it has its inherent 'sweet' spot it likes to convert various signals too.
    FRC Mode Two is probably what your after - 50Hz is converted to 100Hz and 60Hz is displayed at 60Hz.
    Best regards
    Joe
  3. Twan1
    Twan1
    Dec 19, 2004
    1,132
    38
    Essex
    +22
    thanks a lot joe, looks like i just need to djust my settings then i think.
  4. oliverlim
    oliverlim
    Mar 31, 2004
    79
    +7
    Hi Joe,
    does this apply to the 43MXE1 as well? Does it accept 1024x768 native as well over the DVI?
    Oliver
