National Lampoons Animal House
Discussion in 'Movie Forum' started by Ron240, Feb 19, 2003.
  1. Ron240
    Ron240
    Jan 3, 2002
    3,608
    Kirkcaldy (but i'm not a Fifer)
    +452
    I have just received my R2 copy of this cult classic from Play.
    It states on the case that it is 1.85:1 Anamorphic Widescreen.
    Well,not as far as im concerned.:(
    I knew there was something strange when it started playing and i was getting black bars roughly equivalent to what a 2.35:1 ratio would give on a widescreen tv. Then i noticed the picture didnt look quite right,so i checked my picture size setting and found that it had not auto switched to wide,as is normal for all my other DVD's. I then manually switched my display to wide and as expected it became horizontally stretched.
    Has anybody else got this disc and noticed the same thing?
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,317
    Somewhere in South Yorkshire
    +5,670
    According to dvdcompare.....
    "1.85:1 non anamorphic PAL "
  3. Ron240
    Ron240
    Jan 3, 2002
    3,608
    +452
    Yes thats for sure,its certainly not anamporphic:thumbsdow
    Mis-representation methinks.:D
  4. Donnacha
    Donnacha
    Jul 4, 2002
    7,897
    York
    +4,056
    I've got it also, and you're right - It doesn't exactly do what it says on the tin!!
  5. Squirrel God
    Squirrel God
    This has been widely reported on a number of websites and forums.
    It's a printing error.
    There was a R1 collector's edition that was anamorphic, but that's now out of print.
    I bought Animal House R2 from Play as well and it arrived today. I personally don't mind if it's non-anamorphic for the price they're selling it at the moment - especially as there's not an anamorphic version available right now.
    Non-anamorphic PAL is far more tolerable than non-anamorphic NTSC anyway.
  6. LV426
    LV426
    Jul 14, 2000
    13,317
    +5,670
    That depends. On my setup, I can do progressive on NTSC but not on PAL. And NTSC progressive is better than PAL interlaced (all other things being equal - which they rarely are!)
    Even without the progressive factor, the PAL vs NTSC debate has raged for a long time. And the only conclusion one can draw is that some prefer the one, some prefer the other. And image quality can be so very dependant on other factors.
  7. Squirrel God
    Squirrel God
    Yes.
    Non-anamorphic NTSC always looks far worse to me than non-anamorphic PAL when zoomed on an interlaced CRT. Because of the lower vertical resolution of NTSC, I can always see those horrible scan lines when it's zoomed up. They're less visible when PAL is zoomed up. Naturally, if you're not using a CRT, then you're not going to see scanlines anyway, and if your CRT supports PS or 'scanline reducing technology' (e.g. Sony's DRC), then that's gonna make the image more appealing anyway.
