Nasty Xbox questions!!
Discussion in 'Xbox Forums' started by mrapbp, Jan 28, 2004.
  1. mrapbp
    mrapbp
    Dec 28, 2003
    4,933
    83
    Swindon
    +236
    Cant seem to get answers for these questions anywhere??
    Can anyone help?
    1. I am looking at wireless controllers but from what I can see the Xbox live headset will have to plug into the receiver on the console?? Is this true and if so does anyone have a solution cos that defeats the purpose a bit if you ask me??
    2. I want to get a component lead so I can put the Xbox into my Amp for component switching. I also want a digital feed into the amp so I can have 5.1 surround. What lead/leads do I need? As far as I can tell there is nothing that will do the job??
    Thanks!!
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    You can get unofficial wireless controllers for the xbox.
    The xbox live headset plugs into a memory card slot on the xbox controller.
    You need an advanced scart cable, the optical out is on that cable, just plug one end into the cable, the other into your optical in on your receiver.
    Job done! :D
  3. supersonic87
    supersonic87
    Dec 31, 2003
    290
    Swansea, Wales
    There are no wireless pads out at the moment that have the expansion ports on them (all mounted on the reciever module).
    If you require both component AND optical output you will need one of these
    Rich
  4. mrapbp
    mrapbp
    Dec 28, 2003
    4,933
    83
    Swindon
    +236
    Thank you kindly!!
