NAS to Quad Amp / Gale Speakers Recommendations?
Discussion in 'Music Streamers' started by themissingelf, Feb 13, 2014.
  1. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    I have a lovely old Quad 34 / 306 pre/amp combo (and the tuner from the same series too). Currently fed CDs from a Marantz CD52 MkII SE. Linked up to a pair of Gale speakers (from before Richer Sounds(?) bought the brand name (i.e. original Gales)). Sounds lovely!
    However... I have a Sonos 5 in the kitchen and currently ripping all my CDs to a Synology NAS as FLAC files.
    So now I'm considering introducing connectivity between the NAS and the Quad... There appears lots of options and on the surface the Sonos Connect seems the most logical route to go; however, it's important to me that the Quad setup still sounds good.
    As mentioned, I'm using FLAC files; however, I've no idea whether simply using FLAC via a Sonos Connect = good (sound)? I understand CD players - some are better than others - I would "audition" at a shop and choose with my ear. What's the deal with streaming devices - are they all the same?
    Grateful for input and advice!
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    I'd go with the CONNECT, it's good enough for a 34/306 pairing with the advantage of multi-zone using the PLAY:5
  3. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    Yes, the multi-zone has big appeal. Thanks.
  4. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    Would anyone question the rationale of buying a Sonos Connect to "supply" the Quad/Gales vs. buying a Sonos Play 5?
    Obviously I have experience of the Play 5 and it sounds great but can only speculate I will enjoy better quality via the Connect/Quad route.
  5. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    Good though the PLAY:5 is, a proper hi-fi should knock into into a cocked-hat; there's only so much you can do when the speakers are 30cm apart.
    I run a music streamer into my Quad stack fine...
    [​IMG]
  6. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    Better get on and place my order... Many thanks.
  7. smokingreen
    smokingreen
    Apr 23, 2004
    683
    Derby
    +19
    As others have said, go for it. I bought a connect first and then added two more play3 and one play1 for multiple room listening.
    The general consensus is that the sonos connect delivers bit perfect information, so coupled with a good dac it should be the equal of a high end CD player when streaming lossless. Of course not all agree! Personally I use the dac in the sonos itself and it sounds great to me.
    I think the best feature of sonos is how easy it is to use for the whole family, the result is we all listen to more music. I think that matters more than worrying if we are listening to the best possible sound.
  8. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    OK, bit the bullet and got the Connect. Currently I have it connected to the "CD" analogue inputs on the Quad - is this OK or should I be using some other input?
    Would be useful to have it feed into the radio input as that's the default input when the Quad is first switched on. Any problem with that?
  9. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
    AFAIK you'll need to alter the sensitivity of that input on the Quad 34, it's set high for the Quad FM4 so the Sonos might overload unless it's volume was turned right down.
    Nothing would be damaged if you connected the Sonos, set it's volume to zero then gradually increased the volume, leaving the 34 volume set at 12 o'clock just to see how it goes.
  10. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    Just browsing old threads and spotted this update... Slightly confused... The Quad FM4 is a tuner so I don't understand why the CD input (I'm using to connect the Sonos) would be rated for a tuner?
  11. davee
    davee
    Jun 15, 2004
    717
    twickenham
    +57
    Are you referring to the original proper Gales, the 401s?? :thumbsup: or the baby 5 things which came when Gale got into difficulties :blush:
  12. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    301's.
  13. davee
    davee
    Jun 15, 2004
    717
    twickenham
    +57
    Oh, forgot about those. i though for minute you may have had a pair of 401's which would be rare but amazing if in working order.
  14. themissingelf
    themissingelf
    Mar 5, 2007
    98
    11
    The 301s are quite amazing so I'd love to hear the 401s.
