NAS drive with ios & android app
Discussion in 'Networking & NAS' started by shopper150, Aug 18, 2013.
  1. shopper150
    shopper150
    Dec 28, 2002
    632
    28
    +31
    Can anyone recommend nas drives that allow access from ios & android apps?
  2. whitestar96
    whitestar96
    Dec 5, 2006
    582
    28
    +63
    You can try Synology, they have very good mobile apps.
  3. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
    it depends on what you mean by 'access' the NAS.
    I use a ReadyNas, and access my NAS using ES File Explorer, which allows me to manage files on the NAS.
    What are your requirements for the App?
  4. next010
    next010
    May 29, 2005
    10,765
    163
    +2,107
    Synology have the best tablet/phone apps, there are third party tools you can use like ES File Explorer or Network Browser but Synology solutions are easier with the same app across each platform.
  5. cylonwarrior
    cylonwarrior
    Jan 16, 2010
    2,034
    +162
  6. limegreenzx
    limegreenzx
    Feb 9, 2006
    2,018
    +337
    The downside of using an app from synology is that it lacks integration with other network sources. Where as esfile explorer well allow you to easily copy from nas to Dropbox to Google drive to local storage.
  7. charles_b
    charles_b
    Apr 28, 2006
    616
    Berkshire
    +91
    I've not used the Synology App (don't have Synology NAS). What advantage does it have over ES file explorer?
    Considering I'm not about to invest in a new NAS for some time, ES File explorer is at least platform agnostic.
    As far as the OP is concerned, they need to detail what they specifically want from a NAS, and from an App, so that the list of options is not narrowed.
