chrisjoanne
- Joined
- Aug 19, 2003
- Messages
- 216
- Reaction score
- 1
- Points
- 109
I've tried to find the answer to my problem online but unfortunately I've drawn a blank.
I've got a LG Nas drive (which was a pain setting up, but I got there eventually). It works great from home - all my PC's, TV's etc find it and play with no problems. It is also found via my itouch and Android application (away from home).
The address is *myname* and then .lgnas.com
*I obviousy don't fancy putting the full address in the post
My question is, how can the drive be found via apps but not from my netbook or pc when I'm away from home? ie I don't get a "log in" screen. Its a "can not find website" screen.
I believe all correct ports etc are open. I believe the error must be between the PC/Netbook settings and hard drive. ??
Any help is very much appreciated as always.
Chris
Chris
