Narrowed it down to Two
Doctor Smith
Epson tw3500 or Mitsubishi HC3800
What do you think
Mick Turner
I have been struggling with the same question and have decided upon the TW3500. It always seems to be out of or limited stock which suggests it is a popular projector. Could anyone suggest anywhere in the Greater Manchester area where I could buy one?
st tech1
Established Member
They are both supposed to be very good. There are a few reviews around comparing the two.
I am going for the epson 3500 for these reasons:
Lcd rather than dlp
Huge lense shift so flexible placement
Brighter for non ideal rooms
Warranty is better
Bigger image from a shorter throw
Will hopefully get mine soon!
weyland-yutani
Established Member
can i ask why you didn't go for the panny ae3000 from the classifieds, doctor smith? did you find out his warranty wasn't transferable?
Doctor Smith
He still hasnt answered so i guess it isnt
Doctor Smith
I've a TW3500 and have found it to be a superb upgrade from an AE900. Got it from projectorpoint early December and must say had excellent service from them.
What screen are you using, what are the blacks like:thumbsup:
st tech1
Established Member
Just paid for it! Coming wednesday.:thumbsup:
Epson 3500 and panoview 234x132 manual screen.
Its my first projector so I bet it will take ages to set up. Cant wait now.
So much to learn.
I suppose its easier to set up than some because of its lens shift and zoom. I assume it can sit right way up on a shelf 7 foot up in the air or maybe it will have to go upside down?
I will post my thoughts when its all up and running
weyland-yutani
Established Member
make sure you have a tape measure and a spirit level.:smashin:
st tech1
Established Member
It would be a bugger if after fixing projector and sceen to ceiling, that you could not lens shift it enough!
Oops, out with the polly filla!
Must be a nightmare with no shift or zoom.
SteveCritten
Not really mate I got my Infocus X9 with no lens shift roughly where I wanted it then measured the the picture on the wall then ordered a screen and fitted it. Easy really!!:D
Klipsch The Sevens Powered Speaker Review Coming Soon
Back
