Naive yet quick 2011 question
Discussion in 'AV Receivers & Amplifiers' started by Billilu, May 18, 2003.
  1. Billilu
    Billilu
    Do I need 6 speakers to use Neo:6? Is the sound to the 6th channel rerouted elsewhere or is it lost?
    I currently have the 2011 set up with 5.1 speakers, with the surround backs bi-amped to my front speakers.
  2. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    Correct me if im wrong but NEO:6 is 6 channels, ie 5 speakers and the sub so you have no sound to loose. Hope that clears it up.
  3. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    Correct me if I'm wrong too, but if you've connected the amps rear surround speaker outputs to the fronts, won't, when you have a proper es, ex or whatever soundtrack have the sound for those speakers coming out of the fronts? Or shall I go and hide now, having completely misunderstood the situation? (I did a similar thing with my sony amp to the fronts, but using the room B output.)
  4. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    The Pionner has a clever function where you can use the unused amp channels to bi-amp the fronts.
  5. Jeffers01
    Jeffers01
    May 2, 2003
    375
    OXON
    +33
    Using the room B output surely Biwires the fronts. Biamping is different again.
  6. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    No it's biamping...the amps that would be used to drive the two centre rear channels can instead be used to biamp the front pair in a 5.1 set up.
    Regarding Neo:6 it drives my back centre channel (6 speakers) i'm not sure if in a 5 speaker set-up a phantom rear would be generated or not
  7. ChrisNic
    ChrisNic
    May 11, 2003
    1,917
    63
    Thame
    +109
    Its not even as it Neo:6 generates that much signal for the rear channels anyway so its not as it you would loose anything. Its hardly the same as loosing DD-EX sound.
  8. Jeffers01
    Jeffers01
    May 2, 2003
    375
    OXON
    +33
    Yes, using the amps that would have driven the two centre rear channels is biamping but simply using the speaker b outputs as CDB suggested he did with his Sony is surely only Biwiring as the same amps are used but with switchable outputs.
  9. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    Sorry, yes. I'd only skimmed the thread so missed the bit where CBD mentioned his Sony, which as you say would be bi-wired not bi-amped.
  10. cdb
    cdb
    Mar 1, 2003
    475
    28
    +47
    Well, you learn something everyday:D Not that I know that much anyway.:blush:
