Naim Nait 5i compatible with Arcam rDock?
Discussion in 'Hi-Fi Stereo Systems & Separates' started by JonnyBingham, Feb 9, 2009.
Tags:
  1. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    Can the Arcam rDock be connected to the Naim Nait 5i (not newer italic version)? Or in other words, does the Nait 5i have an auxilary input, since this seems to be the only form of connection the rDock uses, unless I've missed an option!
  2. dwhite
    dwhite
    Dec 13, 2001
    7,414
    Whitehaven
    +1,805
    I will move this to the Hifi seperates forum, as its a stereo integrated amp not a AV integrated amp.
  3. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    Anyone?
  4. John Martin
    John Martin
    Jun 30, 2007
    777
    28
    Barton Under Needwood, Burton On Trent, United Kin
    +40
    The short answer is YES. There is no 'auxiliary' input marked as such, but
    that is just a line level input. You can put your rDock into any of the Naim's line level inputs, though of course you have to use the appropriate lead.
    Have a look at the Nait manual :
    http://www.naim-audio.com/download/man_amps_2007_English.pdf
  5. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    Do I have to buy special speaker plugs to be able to use Chord Silver Anniversary XT cable with the Nait 5i?
  6. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    I take it to use the chord cable I have to solder the ends to the 2 plugs that come with the Naim Nait 5i - is that right? Is this a simple job?
  7. John Martin
    John Martin
    Jun 30, 2007
    777
    28
    +40
    The Naim speaker connections are standard banana plug terminals. If you don't feel like soldering the plugs (the Naim supplied ones are just two bananas conveniently in a block), just get a pair of screw on ones from Maplin or equivalent shop. Soldered ones more reliable, but if you're crap at soldering (like me), then perhaps the screwed ones would be a better option.
  8. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
    Can you enclose a weblink (i.e. to Dixons product page) of what these screw-on plugs look like? Thanks a lot
  9. John Martin
    John Martin
    Jun 30, 2007
    777
    28
    +40
    Here's a link to Maplins. They have a variety of banana plugs, some screwed.
    Maplin Electronics ™ Website- 1.5Terabyte Maxtor External Desktop Hard Drive
    Just search for banana plug on that site. I would paste the actual link, but I'm posting this from my daughter's mac, and I'm not too familiar with the way it works. I tried ctrl-c etc but the link didn't seem to want to copy across.
  10. JonnyBingham
    JonnyBingham
    Apr 14, 2008
    216
    Guildford
    +10
