Naim DIN to XLR Question?
Discussion in 'Cables & Switches' started by General Skanky, Jun 1, 2005.
  1. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    Basically, how long would you expect to be able to run a DIN to XLR interconnect for active speakers, before hum kicks in?
    I have two sets, the 5m run is ok.
    However, the 10m run causes the speakers to hum quite loudly, as if there was an earth loop problem.
    I have swapped the cables round and the hum is always on the longer run.
    The cable is an off the reel 'standard' cable made up at the dealer. Ironically, it was fine when it went from RCA to XLR, but now the DINs are on, hum kicks in.
    Any ideas?
    No doubt the magic Mark Grant cable is on the horizon. :D
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    I should add that it is for front and rear speakers from my Naim AV2 to ATC actives.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Now this is one I have never tried, esoteric or what :) This may be a suck it and see job. Have you talked to CHORD or Naim yet about this? They might be able to help.
  4. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    First port of call is my dealer.
    Will let you know.
  5. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    It's possibly a cable capacitance problem. Possibly.
    I'll be at my dealers this afternoon to fit 22 Ohm resistors inline to cure the problem.
    We'll see if it works.
    I believe it's specific to this cable (which is double screened and pretty good by the way), the ATCs and the Naim.
    Never easy is it.
    So fingers crossed.
  6. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
    Well it worked perfectly.
    Naim are spot on for their customer service.
    My dealer fitted the mod today in the DIN plug and it's all fine and dandy.
    I'm certainly very happy.
    One of the morals here is to definately buy into high quality goods from a customer orientated firm and dealer working in tandem to help in any possible way.
    First class service imho.
    A simple little problem (when you know the answer), but helping hands just a phone call away.
  7. Gordon @ Convergent AV
    Jul 13, 2000
    13,998
    +2,802
    Guy: Shining example of customer service. Who was the dealer. Lets give them a plug for actually being a competent specialist!
    Gordon
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,206
    71
    +44
  9. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Glad it worked out, well done Naim and that dealer
