Naim cd 3.5 or Meridian 506 20
Discussion in 'Hi-Fi Stereo Systems & Separates' started by vernster, May 11, 2005.
  1. vernster
    vernster
    Thinking of upgrading my old aura cd player to either a Naim cd 3.5 or a meridian 506 20 bit. Does anyone know what bit the naim is and what sounds best.
    thanks
  2. Samurray
    Samurray
    May 11, 2005
    10
  3. karkus30
    karkus30
    Jul 29, 2002
    13,991
    +1,236
    Chalk and cheese. What are you partnering it with ? What sort of sound do you like. Meridian is a pretty neutral sounding player, where the Naim is more forward with a drier presentation which highlights the midrange and gives a rythmic feel. If you want to listen to HiFi then perhaps the Meridian is the one for you, but if you want musicality buy the Naim. My choice would be the Naim, but theres a lot of people who struggle with the presentation, its been described as lifelike.
