Naim amps- a help please
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by funboy3, Mar 7, 2005.
  1. funboy3
    funboy3
    I am thinking of using an old 90, 140 or 1800 for the centre channel but all these are stereo, can I still use them for just the centre (ie mono?
    Thanks in advancve
  2. Nimby
    Nimby
    Jan 27, 2004
    9,267
    The Danish Bacon Factory
    +710
    Naim has probably the finest and most technically proficient customer service personnel in the world.
    http://www.naim-audio.com/
    E-mail them with your question to get the correct answer.
    I'm not sure running a stereo amp on one channel only is ever a good idea and would strongly advise against mono-ing a stereo amp without the manufacturer's (Naim's) written approval.
    Regards
    Nimby
  3. funboy3
    funboy3
  4. michael.redfern
    michael.redfern
    Oct 14, 2003
    864
    Manchester
    +92
    Funboy,
    Don't sweat it. Whilst it is indeed not good practice to run only one amp, there is a better solution which I use via a Linn stereo power amp. Biamp. :thumbsup:
    Just use a splitter to run two cables out of the centre out on your pre, one into the left and one the right of the power. Then power your tweeters from one side and the bass from the other. Provided of course your centre speaker allows this.
    I've done this before with a Myryad power amp after a thumbs up from Chris Evans (the designer) adn tehn again with the Linn after the same agreement from HelpLinn.
    Have fun!
