Naiko 32"
Discussion in 'General TV Discussions Forum' started by cool hand luke, Nov 23, 2004.
  1. cool hand luke
    cool hand luke
    Anyone got any 1st hand experience of the "Naiko 32" widescreen TV,is it a dog or worth the £249 price i can aquire it for?
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,238
    Manchester
    +747
    Naiko is basically a marketing name for various cheap TVs (often seen at Makro).
    All their products are low end , some made in Hong Kong and China. Wouldn't be at all surprised to see the name on some Turkish TVs from Vestel also (Beko and some low end models from big brand names also use Vestel).
    I once had a 14-inch Naiko NICAM portable in the bedroom ; it worked ok for a couple of years, then developed an A/V switching fault . I was able to prove that the fault lay in the main "jungle chip" on the PCB (and found a fix involving an adding a transistor switch externally on a piece of veroboard ).
    It then went on for another 2 years before packing up beyond economic repair.
    Chris Muriel, Manchester.
  3. cool hand luke
    cool hand luke
    Many thanks Chris for the info,will probley avoid then,although a few years back i bought a 28" NEI model from Makro and it is still going strong and with a great picture.
  4. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,238
    Manchester
    +747
    If you can genuinely find out how many returns they get you might be able to make a more informed decision.
    For that info you probably need an inside contact in your local Makro.
