NAD unleashes new DVD player
Discussion in 'News' started by John Archer, Aug 24, 2005.
  1. John Archer
    John Archer
    <img src="http://www.avforums.com/news/images/20050824192408.jpg" align="right">Following is the press release from NAD on its latest DVD player…</p><P>”NAD has introduced its new T514 DVD/CD Player. The new slim chassis of the T 514 is stylish and attractive, partner to any one of NAD’s high performance A/V Receivers.</p><P>The T514 DACs are capable of reproducing 24-bit, 96kHz audio resolution and Progressive Scan with 3:2 pull down (film detection mode) is integral. Its Component Video outputs include Progressive Scan to get the most out of the latest high-end digital video monitors and projectors, which deliver significantly higher resolution than standard, interlaced video monitors. The T514’s 4x10-bit, 54MHz Video DACs keep signal paths short and direct to minimize interference and are capable of reproducing the finest picture details, as well as true monochrome and vivid colours. The T514 also supports DTS surround sound formats, with the assistance of an external decoder; as well as Dolby Surround formats. It fully supports most popular disc formats, including JPEG, MP-3 and WMA (Windows Media Audio). The DVD-R recordable DVD format is also fully supported. Other DVD recording formats, such as DVD+R and DVD-RAM, may also play properly, depending on which DVD Recorder and blank discs are used.</p><P>For whichever audio format is chosen, the signal will be processed and decoded with typical NAD precision. The analogue output stages are fed from separate regulated power supplies, and utilize audiophile quality parts to retain all the dynamics and detail of the original recoding. The player features three video connection options — component, S-Video and composite — and four for audio — coax, optical, 5.1 analogue and stereo analogue — assuring complete compatibility with any Home Cinema set-up. To facilitate fast and efficient integration into the most demanding whole-house installations, this player provide 12V triggers for remote on-off switching.</p>P>The T524 offers a broad array of capabilities, including Multi-Angle, Multi-Sound, Multi-Subtitle, Frame, 100x Zoom, Marker Search, Smooth Scan, Slow Motion, and Repeat. All these functions can be easily accessed with the supplied remote control.</p><P>The NAD T514 is available now from selected NAD specialist retailers at a suggested price of around £159.95 (including VAT).”
