Question Nad T758 v3 - No sound from tv
Discussion in 'AV Receivers & Amplifiers' started by Gary Brunsdon, Jan 13, 2019.
  1. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    Eastbourne, East Sussex
    +5
    I've just bought the above amp and have managed to get my DVD player and Apple TV setup fine.
    However, when I try to watch my HD Freeview TV I can't seem to get any sound from the amp.
    I've connected an HDMI Lead from the output port of the amp to the 'arc' hdmi port on the tv which I assumed was correct. So maybe I've missed a setting in setup somewhere?
    My previous Marantz av amp had a button on the remote to select tv sound, but the Nad doesn't seem to have anything similar?
    Any advice would be really appreciated - it sounds really great - but I'd like the same great sound from the tv / tv catchup apps..
  2. aandpwoodley
    aandpwoodley
    May 31, 2007
    4,390
    Oxford
    +1,162
    Have you enabled ARC on the TV, ARC can be a bit awkward at times that's why I don't bother with it and just use an optical cable from the TV to the AVR
  3. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    +5
    Yes Arc is enabled, but if connecting up an optical cable will solve my problem... then I'm more than happy to go that route. I guess the sound quality might be better?
  4. richardsim7
    richardsim7
    Nov 19, 2014
    2,801
    2
    London
    +2,126
    Try disabling "CEC/LAN/BluOS in Standby" in the NADs options, do a power cycle of the AVR, and see if that fixes your problem
  5. aandpwoodley
    aandpwoodley
    May 31, 2007
    4,390
    Oxford
    +1,162
    You can normally get Dolby Digital plus through ARC compared to standard DD although how much real world difference your notice is something only you can decide.
    The Optical approach always works and is reliable.
  6. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    +5
    Thanks for all the advice - will have a play around..
    Wondered what doing a power cycle involved?
  7. Rambles
    Rambles
    Jul 14, 2004
    9,758
    137
    UK
    +1,875
    Turning it off and turning it on again ;)
  8. dollag
    dollag
    May 30, 2015
    1,767
    116
    Kent
    +734
    great amp, be interested to hear your thoughts comparing it to your previous marantz
  9. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    +5
    Ok- thanks for all the advice- will report back..
  10. stranger
    stranger
    May 29, 2003
    2,364
    117
    Manchester
    +801
    This "I've connected an HDMI Lead from the output port of the amp to the 'arc' hdmi port on the tv"
    Should go to an INPUT HDMI on the amp (usually one labelled ARC).
    Ignore if it's just a typo in your post of course.
  11. richardsim7
    richardsim7
    Nov 19, 2014
    2,801
    2
    London
    +2,126
    No? OP was correct in their statement, the input is on the TV :)
  12. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    +5
    Disabled "CEC/LAN/BluOS, and all is fine now - many thanks.
    re the sound quality - I feel that the sound for stereo music and for films is so much better than my Marantz SR7011. It just seems so much more detailed,,
  13. richardsim7
    richardsim7
    Nov 19, 2014
    2,801
    2
    London
    +2,126
    Have you run Dirac yet?
  14. Gary Brunsdon
    Gary Brunsdon
    Jan 6, 2008
    371
    +5
    No not yet - a job for this weekend.. hoping that sound will get even better,,,
  15. aandpwoodley
    aandpwoodley
    May 31, 2007
    4,390
    Oxford
    +1,162
    Can only get better when you setup Dirac, I'm a little jealous
  16. dollag
    dollag
    May 30, 2015
    1,767
    116
    Kent
    +734
    I had a similar experiance going from the sr7010 to my arcam. I really liked my marantz but do not think ill go back to them now tbh
