I'm very pleased with this receiver but it does have an annoying quirk. When viewing sky+ through it via optical input it would appear that the fan is on. This causes a low level whirr. If I fast forward Sky+ the noise stops only to re-appear when I hit play again. Any ideas please? Is it normal?
Hi Witters I thought you had sold the nad Has the receiver got plenty of room around it for ventilation.Whats probably happening is when you fast forward the sky the sound cuts out so the amp isnt working hard and when you play the sound resumes and the cooling fan kicks in, My nad t752s fan used to come on quite often but had volume up so never used to really notice it.When you next use the amp press mute and see if the fan turns off.
I did but I missed it Pretty much what I figured. It's not particularly loud so not a big issue. I just wondered.
