NAD T742 humming
Discussion in 'AV Receivers & Amplifiers' started by Matt F, Jul 9, 2003.
  1. Matt F
    Matt F
    Jul 18, 2000
    900
    Chester, UK
    +4
    A mate of mine at work has just bought a T742 (on my recommendation) as a bolt on to his existing 2 channel Audiolab (+Naim) system.
    Everything works fine except there is a hum through both the centre and the rear speakers. The front l/r speakers take a pre-out feed from the NAD and go through his Audiolabs for their power and there is no hum at all on these so it sounds as though it is the power amp section of the T742 that is introducing the hum.
    Any ideas or similar experiences?
    Matt.
  2. andyunique
    andyunique
    i think a process of elimination is needed,try unplugging the feed from the nad to the audiolabs,it may be a grounding problem between both units.if the hum goes it may be because the audiolabs have a mains earth and the nad hasnt.see what you find and let me know
