NAD/Rotel/CA - am I missing something?
cameleyes
Hi guys,
After a new stereo system (upgrade my old old technics mini system). Mainly for watching tv/films and music (cd/mp3).
Under £100 budget - so was thinking any of the following 2nd hand:
NAD C320BEE
Rotel RA-04
Cambridge A5
Cambridge 540A
Am I missing any worthy contender from this mix?
Was thinking of pairing with some QA speakers - (2010 I'm guessing to underpowered) 2020 or 1030i. Budget for speakers £120 tops new or 2nd hand.
Is that a good idea or any other recommendations - unfortunately I don't really have time to get to a hifi shop and listen individually to items so I'm kinda relying on hearsay - I'm sure any upgrade will sound great after my 13 yr old mini system.
Seeker_UK
Add a Creek4040, Marantz PM44 or 52, to the amp list - well worth a listen.
As for the QA, they're all good budget 'speakers and don't worry about the power ratings - unless you've got Krells, you're more likely to kill a speaker with an overdriven lower power amplifier.
Other speakers, if you want floorspeakers, a lot of older Kef (Coda 9) or MS might fit the bill or some Missions might be OK.
danb1979
I dont think you'll go far wrong with the NAD C320BEE; IMO it's the best amp out of the lot youve mentioned and it was am multi award winner ;)
As for speakers; yes the Q Acoustics range is good. If you wanted floorstanders I can highly recommend a set of Acoustic Energy AE 109's via eBay
Superb speakers and will sit well with the NAD :)
cameleyes
Hey thanks very much for reply, will look into creek and marantz.
Can I ask Which would you put at top of list and which at bottom if any?
Seeker_UK
Try the NAD first - you're most likely to find one of those.
