NAD Power Amps
Discussion in 'AV Pre-Amp/Processors & Power Amps' started by JetJockey, Oct 12, 2004.
  1. JetJockey
    JetJockey
    Hi.
    I am thinking of using some NAD C272 power amps (with an AVR300) in order to "Beef up" and possibly Bi Amp my fronts.
    Anybody got any experience of using this particular NAD model or got any views on this?
    Thanks, Gerald. :rolleyes:
  2. innercry
    innercry
    May 10, 2004
    67
    Midlands
    I use a C370 for the fronts in my set-up with a Sony 940 for centre and rears, and it made a big difference, but I dont know how the 272 would work with the AVR300, especially to bi-amp the fronts. However, Ive heard that the C370 bi-amped is supposed to be very "Beefy"! This is going to be my next move for stereo and 5 channel and then maybe a 5 channel Rotel for the rears.
    Regards
    Mike
