Excellent review. What an inspiring product, makes me proud to be British. Also nice remote control. The question is what Stereo HI-FI Speakers would be a good pairing?
But for the last 20 years NAD has been part of the Canadian Lenbrook group, the product was designed in Canada and it's manufactured in ChinaWhat an inspiring product, makes me proud to be British
Oh. Well i am proud of my Cousin who lives in Canada.But for the last 20 years NAD has been part of the Canadian Lenbrook group, the product was designed in Canada and it's manufactured in China![]()
Not directly connected to this particular item but I think the customer service from Lenbrook leaves an awful lot to desire, especially the Bluesound folks. I was seriously going to push the button on a M10
but their attitude persuaded me to say sod you will go elsewhere.
I think you'll find that the M33 will work perfectly with Roon despite it not being "certified". My M32 and M12 (when fitted with the BluOS module) certainly worked well with Roon as I has a Nucleus on loan for a couple of weeks.Would be interested to see how this compared to the Uniti Nova. I'm erring that way because of Roon.
I'm told that my new M33 has identical interface regarding Roon and is as much "Roon Ready" as other NAD products - but check with someone who is using it! Peter
Interesting, though do you mean M32 and M10.No- it doesn't.
The M33 and M10 are perfectly capable of working with Roon (I used the M10 in this fashion for the most part when I reviewed it). NAD has not completed the licensing process though so if you buy an M33 now, it will not work with Roon until such time as this is done.
Well, the 658/298 combo costs £3200 plus interconnects and the M33 costs £4000. I know which I think is best value, partly because I prefer the single-box M33 solution - I hate unnecessary (and always overpriced) cables!I have a NAD C388 with Bluos 2i module and love its sound features and flexibility, how much of an upgrade is the M33? Was also looking at the pre/power combo that uses same amp tech but cheaper the 658/298?
@Ed Selley can you provide any insight to how it sounds connected to a TV without the Chord M Scaler?
Also how you have the sound options configured on your TV (pcm, pass through etc...) and what sources you used (onboard apps, Apple TV etc...)?
Fortunately, I also have a "Roon Ready" M50.2. I've been considering getting a Nucleus or clone, so I should still be able to use Roon with the M50.2 feeding the M32's EAS-EBU input, ie bypassing the non-Roon certified streamer in the M33.
Ed - does this tally with your understanding?
I don't quite agree with the AV review on the comparison to the NAD M10. I also owned the NAD M10 but sold it after 2 months because it just seemed a little strained, thin, and unrefined when played with my 802D2 speakers.
Pretty much- if in doubt, Roon's list (while slower to update) only has stuff that is 100% up and running on it. This includes the M50.2
That's a weird thing to say because that's pretty much what I noted in the review; that it's only with considerably more expensive speakers that the M33 truly begins to shine. Regardless of their value now, the 802D2 was around ten grand new which does rather dovetail with this finding.
I have had my NAD M33 for 6 weeks now and it sounds fantastic with my B&W 802D2 speakers. I love the NAD's crystal clear sound, detail it brings out in all music, punchy bass, big sound stage, and clean dynamic power.
There are a few user interface bugs when the NAD M33 is used with my Ipad and Samsung Galaxy S10 but this has improved greatly with the last few operating system updates.
I was deciding for a few months between the Hegel H390 and the NAD M33 and am happy that I chose the NAD M33!
get a devialet expert 220 pro, roon integration is excellent and better sq than the naims.Would be interested to see how this compared to the Uniti Nova. I'm erring that way because of Roon.
my ex dem 220 was 4400, almost 7k new, i might know where one could be available.Thanks Ed. The M50.2 is certainly on the Roon site as Roon Ready.
The M10 is an excellent one box solution, but I decided to stick with my M32 until the M33 came out. The latter offers the features from M10 that the M32 lacked - built-in streamer, Dirac Live and a bigger LED screen.
The M10 is great matched with speakers that it's appropriate to match it with, but I have Avantgarde Duo XDs and Rick has B&W 802Ds. Both these speakers will benefit more from the better quality M33 than would lesser speakers. I think the M10 deserved its awards, as does the M32. I'm sure the M33 will pick up awards too.
When one has £32K speakers, it's difficult to know where to pitch one's amp budget. I bought or home demo'd a dozen good amps costing considerably more than my M32 but I chose that as overall the best with my speakers. The M33 is a subtle but noticeable step up from the M33 and I doubt I could improve the sound I hear short of a pile of separates costing upwards of £25K - for amp, preamp, DAC, streamer and a snake pit of costly cables.
Can anyone offer a rival to the M33 at a sensibly higher price than its modest £4K? I've failed so far. Peter
Thanks Ed.I'd choose the Uniti Nova on the understanding that;
- I have an affinity for Naim
- I use Roon
- When I don't use Roon, I think their app is nicer to use than BluOS
- I have little need for Dirac, already own a phono stage and only have speakers that have no real requirement for 200 watts to function satisfactorily.
I can easily see why people would choose in the opposite direction though.
Hmmm, thats oddNo- it doesn't.
