colinb07958
I have a nad d3020 and have been having issues with the remote. It is not very responsive and you have to press the buttons several times before anything happens. I have found that pressing hard below the volume down button helps but this is not a solution.
Also can anyone recommend the best way to get the battery hatch open on the remote as they do not supply you with a tool. I managed to get it open with a paper clip but can't get it open now.
Any ideas or any suggestions on a better remote to get. It a shame there is not a app to control it.
Any help is appreciated
Colin
Colin
