NAD C372 Vs. Marantz PM7200KI
Discussion in 'AV Receivers & Amplifiers' started by gregmcquaid, Aug 1, 2005.
Tags:
  1. gregmcquaid
    gregmcquaid
    Aug 20, 2004
    279
    Bristol
    +10
    Looking for a new amp and i am thinking of going for either the nad or the Marantz but i am not sure which would be the better one to go for. I listen to most types of music which is why i am finding it hard to make a decission, what do you think of these two amplifiers?
    Greg
  2. Mentally
    Mentally
    What speakers do you have? The Marantz is softer than the NAD. As a result it is very dependant on your speakers. The NAD will be better if the speakers need some pushing. Otherwise, the Marantz will be great.
