drumcat
Hi all . Just bought a c370 amp which has had some mods done ... 4 caps replaced .. all receipted from a proper repairer . This was done 2 years ago. Met the seller at a service station as didn't want to post . Good feedback and seemed genuine BUT something's not right . Everything works but the volume is low .. I can turn up to max and my speakers are handling it ( they are 12 " AR 11 s ) whereas if use my nad 7125 with 25 watts per channel as opposed to 120 watts per cha on the c370 the speakers are getting loud at only a quarter of the dial. Woofers moving etc. The 7125 has speaker ohm set to 4 .. there is no setting for the nad c370 ..I've gleaned it does it automatically?? ive tried all other inputs and combinations incl different pre outs / speaker outs and spoken to original mod / repairer who adviced might be the pre amp as there is volume but at low level.. it does get loud but at full I'd expect my speakers to blown up ?! ... any ideas what I could check ? I have a meter and soldering iron with limited experience ! I'm at the point of having to drive an hour and a half and knocking on the sellers door. Hes responded with a " it was working " although the remote I got with it had crusty batteries and def doesnt work ...
