NAD c370 bi-wire setup help
Discussion in 'AV Receivers & Amplifiers' started by horley, Jun 18, 2005.
  1. horley
    horley
    Im not sure where to post this, so i thought i would start here. If there is a more appropriate forum to post this on, I would appreciate any suggestions.
    I am as new as they come to audio equipment and have just purchased:
    NAD c370 integrated amp
    B&W DM601 S3
    QED silver anniversary bi-wire speaker cable
    Geko Wire Banana plugs
    The banana plugs fit fine into the 601s, but have no chance of fitting into the c370. In the amp there is Speaker A
    R - + L - +
    and the same for speaker B.
    If i only want to use SpeakerA then for the R - and +, if i bind the 2 - wires together and the 2 + wires together, then they should fit into the amp, but they dont.
    So, should i be plugging one bi-wire sets negatives into speaker A, and then the positives into speaker B? And then the opposite for the other speakers cables?
    Thanks for anyhelp, I am dieing to use these.
