NAD C325BEE Amp - Is it partially faulty??
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Feneris, Feb 8, 2009.
  1. Feneris
    Feneris
    May 14, 2007
    12
    I've got a new NAD seperates system from Superfi. C515BEE CD player and a C325BEE amp with Tannoy Custom F1 speakers. The CD player was replaced by Superfi straight away because it wouldn't read cd's. The Amp also seems to have a fault. It sounds and seems to work correctly, however, maybe twice during a CD album, there will click from the amp (sounds like a relay operating inside the amp) and the music stops for half a second. Then it continues playing correctly untill it randomly does it again.
    The fault has also occured when playing from an ipod, connected with a cable to the aux.
    Is there a fault with the amp, or is something else maybe causing it??
    I'm very happy with the system, sounds very good, I just want it to work!
    Cheers for any help, Simon
  2. Weemfluffer
    Weemfluffer
    Jan 23, 2009
    +4
    Yep, sounds like something is tripping a relay. Clearly a fault. Take it back and get a new one.
  3. Don Dadda
    Don Dadda
    Sep 20, 2007
    5,660
    London
    +728
    Doesn't sound good. How often would this happen?
    Anyway, I would take it back if new, as this sounds like it will only get worse. :(
    They kit they sold you is faulty, not they had any knowledge of it. Get a replacement, not a fix or your money back. :smashin:
