NAD (1155) Pre-amp question
Discussion in 'Hi-Fi Stereo Systems & Separates' started by number 8, Feb 2, 2009.
  1. number 8
    number 8
    Jan 4, 2005
    33
    Hi, I've got a NAD 1155 sterio pre-amp. Athe the back there are setting for CAPACITANCE at either 100pF 200pF OR 300pF. Thing is I've got no idea what these mean or which one I should have it set at, can anyone tell me please?
    One other thing is I've got the option to have the out jacks pluged into a 'normal' or 'high' and I'm not sure which one of these I need to use either. The rest of the set up is; turntables put through a two channel mixer into a graphic equiliser into the NAD pre-amp into a power amp and out of 150w speakers.....:lease:
  2. number 8
    number 8
    Jan 4, 2005
    33
    ....and to add to this I'm only getting a signal through one speaker unless I put the amp into mono mode, then I get mono, but through both speakers. Is this right?
