Naan Bread
DJT75
Joined
May 6, 2005
Messages
11,399
Reaction score
3,853
Points
2,537
Age
48
Let’s face it, nowhere does Naan bread like a restaurant/take away, but occasionally you need to buy Naan breads, for convenience.
I need to buy a load next week to take on a large family trip. They’ll be sat in my car for well over 24 hours so they need to be “convenient”. Where does the best naans or are they all the same cardboardy crap, unless you buy or make the real deal?
I need sealed off the shelf types, or at a push, out-of-fridge sealed ones.
Ta muchly
Our local corner shop does some good ones, so check around your area. These ones are "Punjab Naans"
Ask for Nan bread and they may give you a funny look ;) :)
I get mine from a local halal shop there really nice from there, you could try your local one.
NaaN :).
Just realised bloody iPhone had changed everything to “Nan” for me. She’s long gone & wouldn’t taste great
Make your own? It isnt hard and they dont take long to prove. Ok, they go under the grill rather than in a tandoor but I suspect most commercial produced/packaged ones are not being cooked in a clay tandoor either.
Not an option this week, just need to buy a load
Asda do some and they are the best store bought naans I have had and better than some Indians.
Not every asda stocks then however
Is 4K Blu-ray Worth It?
Back
