N95 Noob question
Discussion in 'Mobile Phones Forum' started by pacemaker, Sep 12, 2007.
  1. pacemaker
    pacemaker
    Aug 31, 2003
    565
    +17
    ok i just returned a samsung g600 and was waiting for the SE 850i, but then my portable PDA with gsm just packed in
    i will be putting a work sim into it so cant access the map stuff
    question is can i download for free the map software fro say Wales and run it the same as my pda in a cradle in my van without connecting to any network?
    if so then it seems this phone will not only replace the SE 850i but also my PDA
    thanks
  2. insomniak123
    insomniak123
    Mar 20, 2007
    2,953
    Balamb Garden
    +370
    N95 maps work in offline mode (i.e no SIM needed)
    you do need to pay extra for the voice navigation though. I find I don't need it as it plans a map, then tracks your position, so you can see in real time when you need to turn off of whatever - but bear in mind you won't get voice directions :smashin:
