N95 Firmware Upgrade now availible
Discussion in 'Mobile Phones Forum' started by haybaby212, Apr 30, 2007.
  1. haybaby212
    haybaby212
    May 19, 2005
    648
    faringdon oxon
    +19
    Hi guys
    Has anyone tried the new firmware update availible from the nokia phone suite firmware upgrader.
    Im at work at the mo and cant do it as it needs the phone plugged into a charger.
    If you have done it does it remove all the orange / vodafone branding so voip will work.
    Ta
  2. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    Just done mine, didn't use a charger.
    If you use Nemesis Service Suite to change your phones product code to 0536062. It will flash it with the generic firmware getting rid of all your phone branding ;)
  3. haybaby212
    haybaby212
    May 19, 2005
    648
    faringdon oxon
    +19
    did you upgrade with the nokia pc suite mate
  4. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    No, there is a separate stand alone program called Nokia software Updater.
    Just go to http://europe.nokia.com/softwareupdate and select N80 as your phone and click on update via PC.
  5. Junglist
    Junglist
    Nov 25, 2006
    820
    28
    In the heart of West Yorkshire
    +91
    Can someone post a link to the firmware update page....I cant find it anywhere.
  6. haybaby212
    haybaby212
    May 19, 2005
    648
    faringdon oxon
    +19
    nah it wont do it with that either says please ensure charger is plugged in press retry to try again.
    No worries ill wait till i get home now
  7. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    There are no links. You can't do it via the website, you need to use the Nokia Software Updater.
  8. Junglist
    Junglist
    Nov 25, 2006
    820
    28
    +91
    Thanks Smokedog.
    Is this the updater that is on the pc suite or do i need to download something else?
    I havent had a nokia in years so this is all new to me.
    EDIT: just seen the earlier post! Trying now
  9. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    Read what I wrote in post no.4
  10. Junglist
    Junglist
    Nov 25, 2006
    820
    28
    +91
    Ok..downloaded the software...ran it...it says there are no updates available.
    Firmware Version = 10.0.018
    Is this the latest version?
    I heard there was a new version on the way n thought that might have been what this thread was about.
    What is the latest version?
  11. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    Ok, read what I wrote in post No.2
  12. haybaby212
    haybaby212
    May 19, 2005
    648
    faringdon oxon
    +19
    you need to change the product code the new version is
    V 11.0.026
    17-04-07
    RM-159
    Nokia N95 (01.01)
  13. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Does anyone know what bugs this fixes?
    I already have a generic version, but would like to see the memory leak problem fixed.
  14. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Ok, it's looking quite good... I have read on a couple of other forums that GPS start up time have been significantly improved with the latest firmware, as has the memory problem. Also, the camera is better and faster, as is the overal menu/UI.
    EDIT:
    :thumbsup:
    Of course this is just a forum post, we need to see more reports and try it ourselves, but it's looking promising. Especially on the memory, GPS front.
  15. MQUIN SKYWALKER
    MQUIN SKYWALKER
    Mar 1, 2005
    590
    LEIGH,LANCS
    +25
    There Isnt One Not On The Nokia Site
  16. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    :rolleyes:
    A) Read the thread before making pointless comments, B) What you said makes zero sense.
  17. MQUIN SKYWALKER
    MQUIN SKYWALKER
    Mar 1, 2005
    590
    LEIGH,LANCS
    +25
    Get Yer Handbag Out Eeeeeeeeeeeeeeeeeeeewwwwwwwwwwwwwwww
  18. Autopilot
    Autopilot
    Feb 5, 2005
    7,629
    Region 2
    +1,516
    Lol, yeah i was kind of expecting that i guess.
  19. eye-ball-paul
    eye-ball-paul
    Dec 30, 2006
    just updating mine now I have figured out how to do it thanks to this thread. I will let you know how it performs
  20. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Question
    For the beniefit of others. Did this update sort out # Key Silent profile?
  21. smokedog
    smokedog
    Aug 4, 2005
    3,046
    103
    +411
    What was wrong with it in the first place? With the new update, holding down the # key activates and de-activates the silent profile.
  22. Sheikher
    Sheikher
    Mar 28, 2007
    52
    I have a sim free N95, using my Three sim in it, will it be ok to update the firmware?
  23. youngsyp
    youngsyp
    Nov 5, 2006
    6,275
    5
    Silverstone
    +1,553
    It will be ok, yes. However, whether you are able to uprade to the new firmware is a different matter. That will all depend on whether there is an update available for your phones product code :smashin:
  24. DustySox
    DustySox
    Aug 25, 2004
    535
    Wokingham
    +10
    Phones brought from stores, ie CPW don't have this facility. Mine...ie O2, does.
    Bit of an inconvenience. This was discussed in the huuuuuuuuuuuge N95 thread.
    Darren
  25. Tejstar
    Tejstar
    Dec 4, 2002
    22,998
    London
    +1,150
    Does Nokia list what the bug fixes are each time a new firmware is released for a phone?
  26. uno
    uno
    Mar 17, 2006
    657
    28
    +90
    How long is it once new firmware comes out do the new phones in stores start having new firmware
  27. thfcmad
    thfcmad
    Sep 22, 2004
    514
    28
    +45
    Just wanted to say thanks. This was really easy to do. I had an O2 branded N95, i changed the product code using Nemesis and then just used the Nokia updater to get the new firmware on. Just have to wait and see how it perform now!
  28. pagibbo
    pagibbo
    Has anyone managed to update and Orange N95. I am having a real problem.
    I have changed the product code to Euro2 and the NSU finds the new firmware downloads it and starts the update. The N95 looks like it goes into Flash mode (dark screen with black NOKIA on it) the update sits there for 5 mins or so then goes into phone recovery mode. Tells me to take battery and power out then re-start the phone. Everything comes back but still on the old firmware 10.....
    The only thing I notice is that when the n95 goes in to flash mode the pc fails ro recognise the device.
    Help I want all the Orange rubbish of my otherwise great phone
  29. haybaby212
    haybaby212
    May 19, 2005
    648
    faringdon oxon
    +19
    mine is orange and i used the product code in the thread make sure you have power plugged in as mine did not work with out it. It might be worth trying a different usb lead or port on your pc.
  30. xplosivmetal
    xplosivmetal
    pagibbo, I had major problems trying this when I first started, the same problems you are experiencing too. My phone is a Sim Free type 66.01 and I used NSS to change to a Euro1 (01.01) type so I could upgrade it's firmware.
    When the software update had rebooted the phone (I'm guessing into Local mode) my computer no longer recognised the phone and reported the USB device was faulty. However I had previously installed a cracked version :)devil:) of Diego and Phoenix to work on another phone of mine :oops: and it was this software that had prevented my computer from recognising the phone in the new mode!! I retried upgrading the firmware on a clean PC and it worked straight away no problem whatsoever.
    This may or may not apply to you but I hope it helps!
