N2050 - 2TB and A-Z menu
eric pisch
I couldnt find any info on anyone successfully using a N2050 with 2*1TB drives so i took a punt and got all the bits
i just started to sky copy+ the info over and was wondering if theres anyway with sky to re organise your list of recorded programmes A-Z as i can see find your way around a problem if this upgrade works
Cyril
Established Member
Sadly Sky's NDS software uses signed 32 bit integers, so the maximum you can use is a single 1TB drive.
If they ever allow the external SATA port to be activated you could in theory use a pair of 1 TB drives, 1 internal and 1 external (just like the TiVo series 3).
As far as I know, no-one has been able to hack the Sky NDS OS, so the only people who can give you the badly needed extra software features are Sky NDS.
I think the disk upgrade is about the only thing we can do with a Sky HD box at the moment.
When prices of 1 TB drives fall I will just put the 1TB in an external caddy and swap them in and out like old VHS tapes :)
If there is demand for a £20k SKyHD equivalent of Kaleidescape with TiVo features I would love to setup a business making a 20TB 20 tuner SKyHD server system for the uber-rich :)
eric pisch
hmm
so im pretty much wasting my time squirting my old drive over atm
i like the idea of swapable caddys, even if you used cheap 500 or 750 drives this could be an easy and reasonably unfiddly option
waht about the A-Z sorting?
eric pisch
used a single 1tb drive seams to work well, upped free space from 7% to 34%
i had some issues on the 750gb with stuttering/overshooting on xMAX forward and reverse and subtitles wouldnt work if u played stoped and then restarted a programme
these all seam fine, may have been a fragmentation issue
i used the latest beta copy+
drive is alittle clackey but better then the 750gb it replace
hitachi 1gb from scan
http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=588415
Im after a couple of cheep ext sata caddys with SATA connectors that dont have the "L" shape on one end, any suggestions?
Sony A84L/A80L BRAVIA XR OLED TV Review - COMPARED to LG C3, Samsung QD-OLED & LG G3
Back
