n00bie time!
RoanS
Hi guys
I know these questions have been asked before, but after months of trawling the forum, I’m still pretty confused. :suicide:
I’ve decided on TH42PW7B, which comes with scart board, & all I want to hook up is my freeview box & pc. I was thinking JS Converter was the way to go for the freeview, & TY-42TM6PB to connect pc (although I’ve had problems sourcing one, any pointers appreciated).
Is this correct, or can I make use of the scart in some way?
Also clarification on the cables would be great.
VGA Cable / SVGA Cables for both connections?
Apologies for being so n00bie, but my heads pickled & don’t want to make any mistakes. If I can clear this up today I’ll be ordering soon as I can.
R
:smashin:
Mep
it has a vga input anyway for the pc, doesn't freeview box have scart out?
RoanS
Hi mep
Yea it does have a scart, but from reading the forum I was under the impression that the JS converter would give me a better picture. I would appreciate anyone opinions coz It would make life a lot easier.
Mep
well yes it should do, and they also do a JS rgb to 3 rca (component) version and you may find the board for that easier ti get(in fact there are 2 possible boards that route...component and the dual component / composite version, which takes up 2 slots)
hornydragon
or put FV tuner board in PC and use that.............then set it up as a Media PC see posts by lisag
RoanS
I’ve just ordered the panel, which will arrive monday. I’m going to check how the scart input looks & go from there. Ill let you know how I get on
Thx for your help guys :smashin:
Rambles
Sounds like a similar set-up to mine.
The Media Center is the way to go but it is developing technology and there are a few teething problems so am using my Pace Twin PVR as back-up.
Within the next couple of months a dual-tuner DVB-T PCI card for MCE2005 should become available, and a Nebula DVB-T PCI card with MCE2005 compatibility, the Nebula, I have been told, should provide excellent picture quality.
I have the Pace Twin connected via Scart, the picture quality is very good, but I am intrigued to know how much better it will be with a JS Tech scart to vga converter. So if you get there before me, please let me know!
I am also having problems sourcing a DVI terminal board, so my PC is currently occupying the VGA input.....
Do let us know how you get on.
RoanS
mep: 123electricals4me.co.uk ;) so far, so good, spoke to them yesterday & ordered on-line today. I’ve received 2 phone calls from them so far keeping me updated.
lisa: Im sure ill be back, & ill keep you informed. I’ve got a pretty good pc atm, so wanted to utilise it.
AMD Athlon 64 3500
Plextor DVD±RW
AOpen Aeolus 6800 GT
Was thinking about a tuner card, but got a little lost & put it on the backburner for now. I was unsure if I would be able to use the pc while my partner watched the tv etc
Rambles
Very nice pc!
The only thing you might find is its a bit noisy, it is possible to source quiet compnents - such as fanless cooling, if you really want to go down a purist HTPC route....
The picture in picture options on the panasonic are very good, I often watch Eastenders and read my favourite forum at the same time....You can also do this just with the PC if you have a tuner card and reduce the app to a little square in the corner of the screen.
hornydragon
r GFC suuports dual display should be no problem to use PC on monitor and feed TV to Plasma at the same Time
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
