N00b question!
Discussion in 'Televisions' started by Patriarch, May 6, 2003.
  1. Patriarch
    Patriarch
    Is Scart and RBG the same? I have my DVD connected via scart, and set the DVD to RBG... is that all? or does it require a special SCART?
  2. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Your T.V. will need to be able to accept an RGB signal comming into it. This is normally stated in you t.v. manual, and the scart it goes into needs to be enabled (usually the first scart).
    The DVD player also has to be set up for RGB output.
    If the t.v doesn't support RGB, then it will automatically change the input into either s-video, or composite, depending on the t.v.
    Hope it helps
    Spunky
  3. Patriarch
    Patriarch
    ok... TV takes RBG for sure. But when I use my XBOX with the advanced RBG cable, the TV says "RBG" sortly.. if I set my DVD to RBG outbut and but it in the same EXT as the XBOX was it says "y/c"
    Also, when I set output from DVD to RBG I get some strange "jaggies", which I dont get when set to OFF
  4. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Strange, the RGB shouldn't produce jaggies (not talking about Prog scan jaggies), i take it you mean theres a diagonal scroll on bight colours and in interactive menu type things.
    This sounds like its not outputting RGB when its on, instead going into composite. hmmmm....
    What sort of DVD player and T.V. are they, also what sort of cable is connecting the two, is it a generic scart that came with them or is it a fully shielded OFC one.
    I 'THINK' the scart must be fully wired for RGB- someone correct me if i'm worng on this.
    Spunky
  5. Patriarch
    Patriarch
    first,... what is fully wired in regards to a SCART?
    Its a 32 inch philips 8807, and some cheap DVD player. The jaggies im talking about is this: When I turnm on the DVD player it displays a blue screen with Yellow DVD on it. The DVD has a slightly fuzzy edge, where as when I turn RGB to "off" it displays each letter very finely. Make sense?
  6. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If the TV says y/c then I'm pretty sure it's seeing a composite signal.
    Assuming that your using the same scart socket on the TV for XBox & DVD, I would suspect that the SCART cable you've got for the DVD is a composite one. Did it come free with the player by any chance?
  7. Patriarch
    Patriarch
    hmm.. cant remember where i got it from I'm afraid... but I counted, and its a 21pin SCART... this should mean its RGB right?
  8. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Not necesarily. Although the plugs on each end have 21 pins, are they all connected?
  9. Patriarch
    Patriarch
    all connected? what do you mean? how can they not be?
  10. Patriarch
    Patriarch
    also... whats the difference between CVBS and Y/C?
  11. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    They may not have wires soldered to all of those pins.
    CVBS = composite
    Y/C = S-Video
    Sorry for the duff info before.
  12. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
  13. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Personally i don't know about the CVBS and Y/C but it definately sound like the scarts not fully wired.
    It might look like all the pins are there on both ends, but inside they won't be wired up- usually a cheap trick they do when they sell you a dvd player, thinking you wont know any better.
    The best thing to do is to get a fully wired one. If you've got any spare lying around it might be best trying with one of those, also see if they look thicker.
    If this is the cas and the jaggies stop, then it'll be off to the shop tp buy a new scart lead.
    Another thing to check is that you haven't got a setting saying NTSC switched on.
    Spunky
  14. Spunky
    Spunky
    Jan 8, 2002
    113
    19
    Norwich/Liverpool
    Doh, two posts while i was writing
  15. Patriarch
    Patriarch
    hehe-... thanks all.. Ill try get a new SCART, and see what happens
  16. Patriarch
    Patriarch
    ok, got a new SCART.. nothing changed... ok.. hold on to your hats, cuz this is weird. I get the best picture by using the EXT2 in the TV which has no RGB, and then setting the DVD output to "OFF"... how weird is that? I really dont get it... i still get these scrolling vertical jaggies on the text... especialy when bright colors are displayed. I thought it might have been due to having too much color in my settings, but since it appears perfect using the method explained above, I guess that isent it...
    ideas?
  17. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Where did you get the new scart from????
    What make/model is the DVD player?
  18. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    You may be using S-video(accepted by EXT2) nearly as good as RGB, Now if you are sure that the scart is fully wired and the TV accedpts RGB have you tried playing with the DVD setup menu? If you are happy with the PQ on ext then stick with it mate other wise I would need to be there and Fiddle in person too work it out, if you have another TV in the house try the DVD on that see if it a wierd TV thing.
  19. Patriarch
    Patriarch
    hey.. the DVD is a Denver.. some cheap ass DVD player, but overall im pretty happy with it. I just dont get it... CVBS (or whatever) and RBG look the exact same...
  20. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    They shouldn't mate RGB should be less harsh and more natural, Composite is buzzy and fake looking, But if your happy your happy, try a friends if you can see if it makes a difference!
  21. Patriarch
    Patriarch
    if I get the time ill make a little video of it :D
  22. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Is it possible that the DVD player won't do RGB???
    and where did you get the new scart cable??
  23. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    It is possible, some cheaper DVD players have S-video and composite only, no way too tell unless its in the manual!
  24. Patriarch
    Patriarch
    hmmm.. the DVD menu "alows" me to output RGB... atleast it gives me the option. The new SCART was bought in a hifi store.. I explained him what I needed.. a SCART that is capable of RGB
