mz-42pz45v and sky +
Discussion in 'Plasma TVs Forum' started by gino555, Mar 27, 2005.
  1. gino555
    gino555
    Mar 27, 2005
    411
    +7
    hi all,
    bought myself my first plasma screen a mz-42pz45v from rs connected it to my sky+ via a S video lead and to my dvd via scart from dvd to phono rca lead in to the screen, i was watching england on the screen and when the camera panned out so the player images were quite small they had a fuzzyness around them phoned rs who said it was sky, phoned sky who said 50% signal and quality strengh was fine so i put a dvd on this worked like a dream
    so i presume it is the sky
    all connections are ok.
    has anybody else had the same problem? and ifso how do I overcome it
    what is the best connection to use from my sky+ to my screen?
  2. gino555
    gino555
    Mar 27, 2005
    411
    +7
    thanks for the help guys!!!!!!!!!!!!!!!
  3. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    i have a panny and the image on that was fine...its not fantastic on footy but was fine...I also have a tiny and that did exactly what you are describing...bbc footy i always find especially bad on both screens....i do not know your plasma but you would maybe find a js rgb to vga converter a much better option than s-video, or even rgb scart.
  4. gino555
    gino555
    Mar 27, 2005
    411
    +7
    thanks for your reply
    what is a js rgb to vga converter or even a rgb scart and also how much do these items cost?
    Gino555
  5. Mep
    Mep
    Dec 25, 2004
    9,673
    Surrey
    +477
    http://www.js-technology.com/produc...id=33&osCsid=12a1fa918d278f887074386431bc3ba9
    there is also lots of info on here if you do a search and normally one or two for sale in classifieds.
    If you have scart input on your plasma a much cheaper option worth trying first is a scart lead bewteen sky and teh screen...set sky to ouput rgb in the services / picture settings menu and use a scart lead that carries rgb signal.
