PJM Images
About a month ago I became the proud owner of a Sony DAV IS50 home theatre system but I've been having an unusual problem.
When playing DVDs or TV through the system or playing Bluray through linked Playstation what happens after around an hour or so is that the system stops playing and start scrolling through all the menus e.g DVD/TV/Radio etc.
It occasionally stops for a second as it seems to latch on again then starts scrolling again. The only way to get a DVD to play again is to switch the whole thing off, eject the disc and start again.
Has anyone got any ideas on what may be causing this?
I've tried changing the HDMI cable but that's not helped. Sony advised to reset the system to defaults and that didn't help. I would normally return for a replacement but it would appear that the system has been discontinued already.
Set Up: Sony 40w 4000 TV / DAV IS50 (via HDMI) then Sky+ Box with Scart to TV and Optical cable to IS50.
Any suggestion musch appreciated.
