My WS TV Has A Mind Of It's Own?
Discussion in 'General TV Discussions Forum' started by Tardis, Nov 14, 2003.
  1. Tardis
    Tardis
    Nov 13, 2003
    480
    28
    +31
    Hi Folks,
    I recently brought a Toshiba 36ZP38. I have wired it up to my HC system and it sounds and look’s phenomenal. I only have one little snag.
    When watching normal TV 1-5, the screen stays on the WS setting, but as soon as I change over to cable TV, it changes to 4:3 ratio automatically instead of staying on WS setting, I have to reset it myself with the remote control and it’s beginning to drive me nuts.
    Please, has anyone got any remedies they could recommend me.
    Tardis
  2. cerebros
    cerebros
    Dec 27, 2002
    1,290
    48
    Leicester
    +29
    Have you done all the simple stuff? i.e. checked that you're set your cable box to output 16:9? Try checking all the simple things first - often the problem can be something so obvious you don't even consider it
