my weak spot is?
Discussion in 'Desktop & Laptop Computers Forum' started by bfrench, May 5, 2005.
  1. bfrench
    bfrench
    May 3, 2004
    138
    surrey
    +3
    hi guys,
    I'm getting a little stuttering playing movies
    from my hard drives, which I think is
    hardware related ( I've tried everything else!!)
    So where would I get the biggest improvement?
    I play using Zoom player / dscaler /reclock / ffdshow
    I can resize to x2 with only 70% cpu usage but I get bad
    stutter and dropped frames. Even resizing to 1024 x 576
    gives a little stutter with dscaler but not if I use powerdvd.
    My problem is that I prefer dscaler.
    My system specs are:
    AMD XP3200+
    512MB RAM
    ATI 9600 radeon
    So what would give me a decent improvement and maybe
    solve my problem? I was thinking of 1024mb ram and an ATI 9800PRO.
    Barry
  2. bigfatsi
    bigfatsi
    Jan 24, 2005
    120
    19
    Teesside
    Which version of ffdshow are you using? Try using a different version. It's a quick one to try and could solve your prob. I'm using the mar3 version and it works well but I had similiar probs to yours on the feb version. Also some say that the older versions are more stable. Give it a go and let me know. Hardware sounds ok but I'm no expert!
    Bigfatsi
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,740
    68
    Warrington
    +27
    Barry: your memory and video card are fine, more memory or a new card will achieve nothing for you as far as your playbck problems are concerned.
    Get hold of FFDSHOW 20041012_SSE and try that, more recent versions seem plagued by performance issues and frankly nothing added since the October 2004 version does anything useful to improve scaling as far as I can see.
  4. bfrench
    bfrench
    May 3, 2004
    138
    surrey
    +3
    Thanks guys,
    well I just tried that version ( i had feb 2004 i think)
    and it has reduced cpu even further 30 - 35%. I now have no
    stutter with PAL but still with NTSC. I am using powerstrip by the
    way 50hz PAL and 71. something for NTSC which seems better than
    48hz (tearing) and 60hz (reclock won't lock on).
    Any ideas?
    Barry
