My Viewing Pleasure
Discussion in 'Members DIY Home Cinema Showcases' started by John, Dec 8, 2004.
  1. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Well Gents ,it all started in 97 when I purchased a Technic DPL mini hifi which I connected to my analogue SKY box and AIWA vhs .
    Bought the tosh in dec 2000 , the YAMAHA htib45 followed in AUG 2001 . SKY+ in MARCH 03 (the VHS was then redundant :thumbsup: )followed by the XBOX in AUG (although I have only just modded it :cool: ) .
    The displays over the years have been ,The obligatory 14in portable . 22in 4:3 . 28in phillips 4:3 .32in phillips w/s.32in hitachi w/s all rented.Finally purchased the Plasma earlier this year
    Next upgrade will be the speakers I think .Been looking at the MS GENIES or possibly the CANTON CD1's as they are available for silly money from Germany.I'm not sure wether the Cantons will offer much above what I have tho.After that will be the DVD player then the AMP
    Currently sit about 2m80cm from the screen . Its about 2m50 from head to rear wall.
    Update Sep05
    Well the upgrades have happened :clap:
    Now have a Pioneer 575a playing the discs
    Yam 757 doing the amplifying
    And new Cantons 50's LCR and 10's at the back and a Canton Sub
    I am currently switching all the Video signals through the amp and upconverting where necessary , So Sky+ via SVid , Xbox and DVD via Component .
    I am still not totally convinced by this method , Plasma settings are a bit of a compromise between all three sources . If I can work out how to get the Amp remote to auto switch inputs on the plasma . Then I might switch back :rolleyes: . Alternitvly , I have my eyes on a Harmony 885 :D
    Gonna try to upload some new piccies , as before they should appear at the side
    Any comments more than welcome
    All the best
    John
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
  3. HMHB
    HMHB
    Nov 11, 2001
    26,852
    Nottinghamshire
    +5,628
    Very nice. How do you hide the cables ? Is it a case of ripping out the plasterboard ?
  4. John
    John
    Dec 13, 2002
    11,305
    +2,922
    I was so close to buying a rotozip to just cut the plasterboard , in the end bought a £3 drywall saw in asda of all places. Very easy to cut , just not very neat to use.Wish I'd gone with the rotozip in the end ,would have been quicker and neater(aswell as another tool for the shed ;) .Turns out my biggest mistake has not been to run a DVI cable to the plasma, what with the latest rumours of SKY HI DEF .o
  5. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Excellent job on hiding the wires, looks very impressive. Its amazing how much space you've gained, its a completley different room.
  6. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Thanks , It feels a totally different room , got rid of the fireplace you can just about see in pic1 ,The sofa is nearer the screen ,which is a good job becuse there is a six seater dining table the other side of it .
  7. John
    John
    Dec 13, 2002
    11,305
    +2,922
    The one complaint I have is that I can't angle the rear speakers down enough.Hope to over come that with the next bout of upgraditis tho ;)
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Nice job :)
  9. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Cheers Mylo , This section could do with being a bit more prominent in the forums
  10. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Can't believe I only gave myself one star ;)
  11. HTnewb
    HTnewb
    Good work! After you chased the walls, what did you use to fill it after?
    thx
  12. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Just used a ready mixed plaster to get it close .The decorator I had filled the rest smooth , and papered over. Best £700 spent ,getting a decorator in
    John
  13. John
    John
    Dec 13, 2002
    11,305
    +2,922
    Now Updated
