My TV is not showing the full picture.
Discussion in 'General TV Discussions Forum' started by Shreddah, Mar 31, 2016.
  1. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    My PANASONIC VIERA TX-55CX400B is not showing the full screen on the tv show. It seems to be cutting some parts out. Before when I put my tv on auto it will cover the entire screen but now it has 2 black bars on the sides. Even when the TV was without the black bars it still seemed to look like it was cutting some parts out. Any help with this? Also if you can't help how can I remove the black bars on auto mode and put it atleast back to how it was before. Additionally I did some searching and it said I need to enable "full" mode and put it on "size 2" however I cannot find any option to find out how to enable/disable full and put on size 2.
    -Thank you in advance.
  2. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    Set your Tv to 16x9 widescreen.
  3. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    I can put it on 16x9 but there's no "widerscreen".
  4. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Unless it's under a specific category which I'm missing.
  5. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    What are you viewing?..,built in Freeview?...if so, are you maybe watching a programme made in 4x3?
    Or are you watching a set-top box on an AV input?
  6. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Digital Cable e.g Sky digi box.
  7. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    Jeez, "Digital cable" isn't Sky...hang on, are you in the UK?
  8. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Older Sky+ and no it isn't
  9. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    Right, let's start again...are you in the UK?
    Is it definitely a Sky Satellite box?
    Is it connected by scart lead and are you viewing it on the scart input of the Tv (rather than on the analogue tuner).
    If yes to all these go into the Sky box picture settings and set the output to 16x9 widescreen, RGB video output and "scart control" to on. Don't forget to press the button to "Save new settings"
    There are 2 scart sockets on Sky+ boxes, make sure the scart lead is plugged into the one marked "Tv Scart" which is usually the bottom socket on some boxes but it's printed next to the socket so get a torch if necessary and double check.
    Set your Tv aspect ratio to "Auto"...just be aware if it's a modern 16x9 widescreen programme you're viewing it will fill the screen, if it's an older 4x3 programme you will get black bars either side and if it's a movie on one of the Sky Movies channel it may be in 2.35x1 in which case you'll get black bars top & bottom...this is normal and is the way these are meant to be viewed.
  10. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    How do I enter the sky box settings? Sorry if I seem like an absolute idiot I'm new to stuff like this.
  11. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    On the Sky remote, "Services", "Picture Settings"
  12. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Alright, Thanks! This helped a lot.
  13. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Oh yeah just to add, it only says 16:9 not 16:9 widescreen. I'm guessing it makes no difference, anyhow the screen is definitely A LOT better and once again thank you.
  14. JayCee
    JayCee
    Jan 20, 2004
    22,857
    Lanarkshire
    +2,425
    Yes, it's just 16x9, glad to help, but do yourself a favour, replace the old Sky+ box with a SkyHD box connected by HDMI and you'll see a massive increase in picture quality.
  15. Shreddah
    Shreddah
    Mar 27, 2016
    13
    U.K
    Heh, alright.
