Well well well!
There's no doubt about it, the ld920/950 is better than
Toshiba 2011 passives, 42 and 47
The good the bad
No 3d film smoothing BAD
8ms pixel response time BAD
Extremely good input lag! EXELENT
Xtalk GOOD
lg 42lw450u passive.
The good the bad.
Alittle laggy but did'nt affect my gaming but the tosh showed it to have quite alot of lag GOOD/BAD.
Colourbug for interleaved 3d.BAD.
3d Film smoothing, Exelent
Proccessing issue's that is mostly cured by Game AV. BAD
Xtalk GOOD
Lg pz550t plasma
The good the bad
Terrible picture, not cery sharp and rough around edges.BAD
Can't handle a white screen, goes grey! BAD
Colourbug for checkerboard 3d BAD
Can't remember lag as i only had it a few days and thought it was garbage BAD
Xtalk, BAD
Phillips 32pfl7606 passive
Small, for me BAD for someone who likes 32" GOOD
No lag, alittle more than the tosh though but not as bad as the 450u. GOOD
No colourbug for interleaved 3d GOOD
2ms pixel response time EXELENT
Xtalk ok GOOD
Lg 47lk950u passive
2.4ms pixel response time EXELENT
Gaming lag BAD
Xtalk TOP OF THE CLASS
3d Film smoothing GOOD
Lg 47ld920
Gaming lag seems tobe about the same as the philips MATCHES 7606 EXACTLY, used lag tester and cloned displays.
No colourbug with mod GOOD
3d film smoothing EXELENT
Xtalk TOP OF ITS CLASS
The lk950u and the ld920/950 Do give the best 3d xtalk performance out of all the sets i've seen in 2011 wether they was my tv's or mates.
The ld950/920 has no bells and whistles so its no smart tv.
I've only included the info for the tv's i've owned so i suppose the ld's beat all the tv's i've had.
Edit
Now things are starting to become clear.
After watching a certain film on the 47" tosh passive/lk950 i now just watched the same film with the ld920.
This only affects 3d proccessing, my 3d interleaved image is'nt affected as there is no 3d proccessing going on.
The ld920 in 3d at 1080p resembles Smooth video projects " reduce resolution " at around 720p.
The most obvious thing is that lg had to Reduce res to have 3d motion settings active in 3d, this is why the res looked so low, it has nothing todo with teh fpr screen as it was lg's software that is reducing the res of the image to give it more performance to use with 3d motion settings on, this is exactly teh same way SVP works if we set the setting to reduce res.
The new algorythm obviously does'nt decrease the res very much, again this is proved via SVP's " reduce resolution " as i can reduce res in svp to match lg 3d.
Allso note that i'm 99% sure the lk has a sharper 3d image just like all of lg's 2011 sets that got teh new algorythm.
Allso i believe the philips and the tosh could do 3d film smoothing but they decided agianst it and just went all in on teh better algorythm instead of giving a option for lower res but smoother image.
Even with the 920's lowered 3d res it still matches the ld and beats all the other 3dtv's i've had for interleaved 3d gaming and films, i'f i'm more happy now than with any other tv apart from ld then that really does mean something
If you have a ld920/50 there really is'nt much piont in spending your money on another passive yet, they are still very good even by todays standards.
The good the bad
Xtalk GOOD
The good the bad.
Xtalk GOOD
Lg pz550t plasma
The good the bad
Xtalk, BAD
Xtalk ok GOOD
Lg 47lk950u passive
Gaming lag BAD
Lg 47ld920
Edit
