My Tosh has started to humm - Help!!
Discussion in 'LCD & LED LCD TVs Forum' started by ikon66, Jun 15, 2005.
Tags:
  1. ikon66
    ikon66
    Mar 22, 2005
    419
    Tyne & Wear
    +3
    Had my 30" Toshiba Stasia 30WL46 since Easter and when I was playing with the picture settings I started to get a humm from the back - right of the set.
    Is there a fan in the tv? if yes why has it not been on before?
    Any other suggestions welcome
  2. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Join the club. I've had a 37WL56p for the last three weeks and it has been hummmming since I first switched it on. Write down the batch and serial number and call Toshiba customer services on 08704 424 424 and discuss the issue with them. I've had an engineer out twice to this. It is a faulty mains transformer board inside. I've written alot about it on various threads and I'm not the only one to have this problem. Let Toshiba know, they should do something about this as there are too many people suffering with it. I know other Tosh LCD owners and they are getting this problem...
    I hope that this helps? :lesson:
  3. ikon66
    ikon66
    Mar 22, 2005
    419
    Tyne & Wear
    +3
    cheers rob
    will give them a ring in the a.m.
    Paul
  4. SMooV
    SMooV
    Mar 2, 2005
    23
    4
    Tayside
    ikon66
    When you were playing about with the picture settings, did you increase the backlighting? I have the same model, and have noticed that more backlight = more hum!!
    If you did turn it up, turn it down again and hope that its that simple. If not then youll probably be heading down the same road as Rob Sheep!
    Si.
  5. ikon66
    ikon66
    Mar 22, 2005
    419
    Tyne & Wear
    +3
    smoov, I had actually tuned it down and that caused the humming, tuning it back up stopped it :thumbsup:
    thanks for the input
  6. tools
    tools
    I have a 27WL56p its only three weeks old and already has a two problems I have codes flashing up on it 5 to 7 times a day and the sound has a buzz on it. I have had an engineer came out and said it has a mircoprocessor fault on it. I am now going to send it back and get a new make and set alltogether not to sure which one to get but anything has to be better than this!
  7. Rob Sheep
    Rob Sheep
    Aug 17, 2003
    155
    16
    Worcester
    Tools, Ikon66,
    The buzz is a problem and Toshiba should be contacted about it, as far as they are concerned there should be no buzz. I've had the bar codes but for some reason that has now stopped. If you have these sets try and play nonanamorphic dvds, I can't play any so I'm having to reorder many dvds from overseas, its pleased my wife no end, I dread to think what the payback is going to be for this!
    I'll let you know how things turn out if you need any further info let me know. :clap:
