My System - is it worth upgrading??
Discussion in 'AV Receivers & Amplifiers' started by Madman045, Oct 17, 2003.
  1. Madman045
    Madman045
    Oct 17, 2003
    Hi all.....
    I currently have the following system, ive had for over 5yrs, just wondering if its worth upgrading of any it, mainly the Amp/receiver & cd player
    The upgrade is purely on a quality basis.
    I have 1 pair of Kef Q15 bookshelf speakers, 1x Nad 710 Amp/Receiver & Nad 522 cd player.
    Ive heard different systems over the years, quad electostatics powered by a valve amp etc. :D
    Thanks for any advice given..
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Well are you looking at possibly AV are you unhappy? You could demo some new kit try some new gear but what sort of budget etc are loking at spending, do you want more features better sound etc?
  3. Madman045
    Madman045
    Oct 17, 2003
    Hi HD
    Mainly sound quality, a friend of mine has his own audio shop, so i have been brought up with seperates & this was my 1st system i got.
    Im very happy with the setup, just can it be improved?
    if anything the cd player is 1st on my list
    Speakers are connected via some decent cable & banana plugs
    is it worth getting a seperate amp & reciever or am i gonna have to spend loads to get better sound?
    Or am i better off sticking with what i have?
    as for the budget, nothing silly £100-£200 cd player etc..
