My subwoofer died
Discussion in 'Subwoofers' started by brucevideos, Jan 31, 2005.
  1. brucevideos
    brucevideos
    Hi there,
    I have a set of KEF egg speakers along with the PSW 2000 subwoofer. The other day I noticed that the sub appears to have broken. The power light is on, but it is not outputting anything, not a rumble.
    I am no expert so I have no clue what could be wrong, but it no longer makes a little "click" when it's powered on, which I guess is pretty important. Does anyone have any idea what might be wrong with it, and would it be possible to fix without sending it away? Thank you!
  2. Magnet & Steel
    Magnet & Steel
    Jan 14, 2005
    108
    16
    sounds like the dreaded blown fuse issue again. im not sure where its located on your sub, but have a look where the mains lead plugs into the subs amp for a little pull out tray if it has one, youll be able to see if its blown or not. then a trip to maplins.
