gamingdave
Established Member
My sub appears to be faulty but can anyone help diagnose the possible fault?
It is a (nearly) 10 year old Acuostic Energy AE108s - link
It hasnt been uesd in a number of years, as I simply havent had room for it, untill now. It is plugged into a Yamaha RX-V3800 via the sub out on the amp, to one of the inputs on the sub. I haev tried both inputs on the sub, and several cables from the amp.
When I switch it on at the mains, it lets out a low thud, which sounds like the amp switching on, coming from the speaker. However when running either tests from the amp in the setup, or playing content, I hear absolutley nothing from the sub. I have tried changing the crossover and volume levels, but they do nothing. This is the same whether the amp is set to On or Auto.
Can anyone suggest any tests I could do to verify what may be the problem?
Many Thanks
Many Thanks
