My SkyHD box is stuck on a System software update screen
Discussion in 'Sky Digital TV Forum' started by suttonsboot, May 8, 2007.
  1. suttonsboot
    suttonsboot
    Dec 29, 2005
    45
    11
    For the last 2 days. I've plugged it out and back in. I've rang Sky they said it wasn't their problem as i bought my own box and installed it myself. Any ideas what to do??:lease:
  2. superbike999
    superbike999
    Mar 16, 2006
    242
    Southport
    +19
    Try holding the backup button down when you plug it back in & see if you can force an update, or is that what you were trying to do when it got stuck?
    Dave
  3. suttonsboot
    suttonsboot
    Dec 29, 2005
    45
    11
    I've tried that but with the same screen. I'll leave it for 10 mins and see how it goes. Usually it clicks off after that as if the update was finished and then just starts the process over again. Thanx for yer help
  4. suttonsboot
    suttonsboot
    Dec 29, 2005
    45
    11
    :clap: :clap: :clap: :arty: Nice one pal. That worked
