My sky remote wont work.. no flashing red light
Discussion in 'Sky Digital TV Forum' started by Lolly1987, Mar 31, 2010.
  1. Lolly1987
    Lolly1987
    Feb 22, 2010
    14
    My sky plus remote will not work.. When i press any of the buttons on the control it does nothing.
    I can not use the remote at all. I have only had it since November last year.
    Does this mean its competely broken?? PLease help.:lease:
  2. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
    1. Have you changed the batteries?
    2. Leave the batteries out of the controller for 24 hrs, and try again.
  3. Lolly1987
    Lolly1987
    Feb 22, 2010
    14
    I have changed the battiers thinking that could be what the problem was.. i had no warning messages about the battiers though.. which it normally does when they need changing.
    Ok i will try leaving them out for 24 hrs thank you!!:thumbsup:
  4. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    A quicker method (direct from Sky) is to remove one or both battery cells and press the "select" button for a minute. This should remove any remaining charge in the internal capacitor and reset the remote. Replace battery and it should work.
  5. Lolly1987
    Lolly1987
    Feb 22, 2010
    14
    Thank you so much. Yes it has worked.
    Thank you for every ones help :) :clap:
  6. logiciel
    logiciel
    Feb 2, 2008
    53,064
    UK
    +5,739
    MP - you forgot about pointing the battery at something.:D
  7. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Yes, I was sooooo tempted to mention that. ;)
  8. logiciel
    logiciel
    Feb 2, 2008
    53,064
    UK
    +5,739
    It's not like you not to yield to temptation. I found it easy.
  9. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Don't mention temptation while I have a bottle of "raki" in my hand. :rolleyes:
    Did I mention that it's sunny here? :cool:
  10. logiciel
    logiciel
    Feb 2, 2008
    53,064
    UK
    +5,739
    You going to do some paintstripping then?
    It's sunny here too but no doubt less hot and fishy.
  11. AVn00b
    AVn00b
    Sep 29, 2007
    34
    my sky+ remote control's mute button and the volume button is not working, is there way of making them work. help much appreciated.:lease:
  12. Stevenage Neil
    Stevenage Neil
    Jul 14, 2008
    9,826
    +897
  13. michaelf55
    michaelf55
    Nov 18, 2005
    33
    St Blazey, Cornwall
    Isn't the internet a wonderful thing - this tip has just worked for me too! First time after a minute it was no good but I then left the batteries out for 5 minutes, pressed again for a minute and Bingo so thanks for the help. (PS Someone on Ebay is selling "how to mend your sky remote" for about £1.20 which I imagine is sending them this nugget of information!)
  14. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Feel free to send me the £1.20. :)
    Or at least show your gratitude by reading my monthly Satcure "blog". I spend days writing it and, judging from the feedback, hardly anyone reads it. (Maybe it's because I whinge a lot?) :blush:
  15. logiciel
    logiciel
    Feb 2, 2008
    53,064
    UK
    +5,739
    No, it's because you tell all the details so they don't have to get back to ask you for any more.
  16. londontone
    londontone
    Oct 28, 2008
    Hi all,
    Quick thanks for the "no red lights on remote" fix.
    Removed batteries and held the select button for over a minute and it sprung back to life !
  17. MartinPickering
    MartinPickering
    Sep 23, 2009
    4,953
    Greek Island
    +507
    Our island fire engine has the same problem. The driver has tried taking the batteries out but is struggling to find the "select" button. Any suggestions?
  18. nicenurse63
    nicenurse63
    Sep 3, 2012
    was doing my head in big style tried all other sites suggestions but all failed :( when i did as recommended above (ie removing batteries and holding select for one min before replacing batteries ) it worked atreat !!!!! thanx so much saved my sanity lol
