My Sky+ Installation dilemma
Discussion in 'Sky Digital TV Forum' started by Ango, Dec 19, 2003.
  1. Ango
    Ango
    Jul 2, 2003
    174
    I have only just heard that the LNB needs to be changed to a quad LNB and an extra cable has to be ran to the box. This is however a problem for me. As the box is on completely the other side of the house, and its a big house. Im not entirely sure if sky will be able to do it themselves. Last time we got someone else to install it, however that company has now gone bust.
    Do you think sky will be up to the job? I dont want to spend any money calling anyone else in...
    If they cant do it, will I be refunded or what? They do say £1 installation..
    Thanks again for all your help.
    Andrew
    Also, is the cable they supply very long?
    CHeers
  2. JAMBO
    JAMBO
    I don't see why Sky shouldn't be able to install it. The cable is not of a specific size, it is cut to size from a drum of cable by the engineer. Since the dish has to face roughly south, I'm sure plenty of people require it to be on the opposite side of their house to their lounge (or wherever their TV is). They should just run the cable from the dish, along the outside wall of your house and through the wall at a point near your receiver.
  3. Techno
    Techno
    Nov 20, 2003
    312
    I was in same position as you, BIG house (at least that's the polite term for what the engineer said when he saw how far he had to go:)), Dish one side, TV the other. They fitted it no problem, did a nice job too - can't see the wires at the front of the house.
  4. STOWITBELOW
    STOWITBELOW
    Nov 17, 2002
    1,578
    48
    Lancashire
    +49
    I've recently changed to +, & although you do need 2 feeds from the dish, this is done with some sort of twin cable, rather than 2 singles. I'm sure Sky will tell you if there's a maximum cable run that incurs extra charges. As for £1 instalation, see
    http://www.avforums.com/forums/showthread.php?s=&threadid=107824
    Their original offer ended.
    I'm getting a complex with no response!!
  5. Ango
    Ango
    Jul 2, 2003
    174
    I got the Sky+ for the £99 + £1 installation deal.
    Can someone confirm that its a twin cable they use, instead of two seperate cables?
    Thanks for all your help so far
  6. Techno
    Techno
    Nov 20, 2003
    312
    Was with me.
  7. JAMBO
    JAMBO
    2 seperate cables for me. I already had Sky, so don't know if they use a twin cable for new installations and another seperate cable for upgrades, or if it's just down to what engineer has in his van.
  8. Tony Roma
    Tony Roma
    Oct 4, 2003
    1,928
    Essex
    +48
    Only sky installers have the twin cable, sub contractors dont use it as it is too expensive, it just depends who turns up on the day.
  9. Techno
    Techno
    Nov 20, 2003
    312
    Mine was effectively a new install - so I assume then that if you are having Sky+ in the same place as your old Sky box they just run another single wire rather than taking out the old one. If it's a new install or (as in my case) in a completely different place they run twin rather than two singles.
  10. xyznicko
    xyznicko
    Depends on how long the run of cable is, if its too long they use two cables of higher quality for better signal strength, if its short they can use the twin core cable.
    Mine was about 14 metres in length and the installer advised that 2 cables would be better.
  11. Ango
    Ango
    Jul 2, 2003
    174
    The distance from dish to box for me is about 30 metres.
  12. Techno
    Techno
    Nov 20, 2003
    312
    Mine's at least 23m.
  13. wozwebs
    wozwebs
    Jul 10, 2003
    1,165
    +112
    I had normal Sky installed by Sky but I told the chap I would soon buy Sky+ so he used 'Dual Cable' as he said it. I have since purchased a v1 Sky+ box from ebay and used the cable the chap put in upstairs downstairs into the 2nd input from the dish.
    How can one 'twin' cable as mentioned above go into two inputs? Me confused!!
  14. Techno
    Techno
    Nov 20, 2003
    312
    It's basically two cables stuck together
  15. wozwebs
    wozwebs
    Jul 10, 2003
    1,165
    +112
    So could I 'split' the cable and put it into the two Sky+ inputs? (providing he did the same at the dish end?
