My Sky HD box is slowing down.
Discussion in 'Sky Digital TV Forum' started by 7hil, Dec 25, 2006.
  1. 7hil
    7hil
    Apr 5, 2006
    1,649
    Sydney
    +145
    Channel changing, menu response times, live pause, everything is starting to become slower and slower. Almost feels like the drive needs defragmenting. Anyone know how to do this?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Defragging the drive as such won't make any difference to the speed of the menus or channel changing:)
    Since you are recording single files in the gigabyte range there is little fragmentation going on compared to a PC system writing millions of 1k-1gig files.
    A simple reboot has been found to give a struggling system a boost, go into standby and let the drive spin down then simple power off and on at the plug.
  3. Giblets2
    Giblets2
    Jul 23, 2005
    2,277
    +183
    If that doesn't work search on here for how to do a 'planner rebuild', that will normally sort it.
  4. 7hil
    7hil
    Apr 5, 2006
    1,649
    Sydney
    +145
    Excellent. Thanks for the help! :thumbsup:
