My Set up - does it look right?
Discussion in 'Home Cinema Speakers' started by phillips321, Jan 7, 2005.
  1. phillips321
    phillips321
    Here are pictures and a little diagram to show my speaker placement, what im trying to find out is if they are all postioned correctly. More importantly i would like to know what delay settings i need for each speaker.
    [​IMG]
    [​IMG]
    Should the rears be facing inwards to wards each other or towards the TV?
    [​IMG]
    I have a Yamaha A5 and it allows between 0 and 20ms for the rear, im not sure how much it allows for the centre.
    From the diagram below is it possible to identify the correct delay timings that i need from calculating the speed of sound ect?
    [​IMG]
    Cheers guys
    P.s. bonus points for guessing the film on the TV
  2. Strobe
    Strobe
    Aug 29, 2003
    2,824
    Southampton
    +597
  3. Strobe
    Strobe
    Aug 29, 2003
    2,824
    Southampton
    +597
    Sorry...just showing my age.
  4. Strobe
    Strobe
    Aug 29, 2003
    2,824
    Southampton
    +597
    I would have put the rears higher up on the walls facing forwards.
  5. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    Front speakers are fine but as Strobe said you could do with some tinkering of the rears. For some reason or other I find it difficult to see pics clearly on my monitor but I think that you may have problems with your rears as if you face them forward they may be be too close to you and they don't seem to be well positioned at the moment.
  6. GazTheHat
    GazTheHat
    Dec 15, 2004
    216
    Strathaven
    +16
    Are the rears facing each other? I'd play around with that if i were you....isn't that half the fun? :)
    I just swapped/upgraded my system to Kef Eggs, as the Wharfedale 8.2's as rears were just too big i felt, even with 2m-ish to the seating area.
  7. roman-r
    roman-r
    Jun 11, 2004
    6,010
    83
    London - Stoke Newington N16
    +149
    Nice setup there :thumbsup:
    Theoretically you should move the front left and right speakers forward 15cms so all are at the same distance from listening position and you should also use the same length speaker cable between these and the centre speaker.
    Not only will this eliminate timing between centre and fronts but will also help reduce boom from the floorstanders being too close to the wall :)
    I'd also spread them further apart - a guide is they should be a metre away from the TV - but 50-60 cms would do nicely in your case.
    Rears more of an obvious problem and you could do what i do to solve it by moving the sette forward when you want to watch TV with the amp - might also make you watch it a little less so you can take your lovely girlfriend out a little more ;)
    As others have said, they arn't ideally placed but with rear speakers that large maybe small (.5 mtre) stands for them on the floor and a little wider apart would be a good compromise.
  8. phillips321
    phillips321
    i cant believe none of you guessed the film. come on guys, think. Its a very very popular sequal to an amazing film, there is also a third after this one.
    Also can any calculate the timings for me?
  9. phillips321
    phillips321
    also one main thing that my partener goes nuts about it that none of the speakers are matching, all different colours. I am the only one that gets moned at?
  10. Gorecon
    Gorecon
    Oh I can't resist.
    It's Terminator 2 isn't it.
  11. JiMbOb_74
    JiMbOb_74
    you should never face speakers directly at each other! it will sound awful
    Just face them outwards if thats the only place you can put them
  12. Tejstar
    Tejstar
    Dec 4, 2002
    22,496
    London
    +995
    That's what I think too :D
  13. phillips321
    phillips321
    yep its T2 guys, the scene when the liquid metal guy walks towards the flames in the factory at the end
    T1 = Very good sound
    T2 = Very good special effects
    T3 = CRAP!
  14. nero0410
    nero0410
    Jan 5, 2004
    11,632
    southwest
    +4,395
    I would personally mount the rears either side and up slightly higher on the walls, and widen the distance of the floorstanders to match them too
    tris
  15. rozzar
    rozzar
    Sep 29, 2002
    1,046
    41
    Braintree
    +23
    and put your missus/sister in the correct listening position :laugh:
    p.s. the bird in T3 is muhasssively fit and T3 is a top movie anyway but arguably not as good as the DTS-ES 6.1 Ultimate version of T2.
