My screen has turned Green using RGB?
Discussion in 'General TV Discussions Forum' started by CarlosTheJackel, Dec 16, 2002.
  1. CarlosTheJackel
    CarlosTheJackel
    Using a scart from my Sky Digi box to my TV everything was fine. So i decided to upgrade my scart cable to a THOR 26481T, the only problem is with this cable my picture is green!? Any ideas anyone?
  2. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    have you set the digi box to rgb.
  3. TommyP
    TommyP
    Nov 7, 2002
    63
    Maidenhead, Berkshire
    Mine has just done the same although it's when i plug my old Goodmans DVD player into the TV. RGB gives a green hue to the picture but Composite is fine.
    Strange thing is that my new Sony DVD plays everything fine using the same cable and same AV connection.
    :confused:
  4. CarlosTheJackel
    CarlosTheJackel
    Yup, RGB was working fine with the cheap cable, now its gone all green. Its fine when NOT on RGB.
  5. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    right has the scart got a switch on it. as my new rgb cable for the ps2 did. & when i first put it in the screen was green. then i noticed the switch so used it & bingo great picture
  6. CarlosTheJackel
    CarlosTheJackel
    There is NO switch on the Scart. This is what Philex Thor said
    I cannot find and AV setings in my KV32FX66 menu but the Digibox is set at RGB! WTF is sync on green, sounds like a boy band
    :confused: :)
  7. brichards
    brichards
    Jun 7, 2002
    +16
    :( Your recorder or whatever u are using is not RGB compatable.
    Hence the green. You will have to set your digibox to Video.
    It will work on composite because it is a composite of all colours and it is a compromise.
    Good luck.
  8. CarlosTheJackel
    CarlosTheJackel
    Its from my Digibox which has RGB to my Sony KV32-FX66 which is supposed to have 2 RGB sockets and 1 non. I've tried it in all of them. I've been through all the settings, im off to try a different Thor scart just in case its a faulty cable as the colour is more Turqoise than green so it could be missing red!
  9. CarlosTheJackel
    CarlosTheJackel
    Well the other cable works fine, so it looks like a dodgy cable!
  10. RichB14
    RichB14
    Nov 8, 2002
    784
    Surrey
    +19
    Carlos
    Where did you get your thor from and how much
  11. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    the borg maplin sell the thor cables thats where i got mine.
  12. CarlosTheJackel
    CarlosTheJackel
  13. RichB14
    RichB14
    Nov 8, 2002
    784
    Surrey
    +19
    cheers guys
  14. sparkymarky
    sparkymarky
    Dec 12, 2002
    1,186
    48
    cornwall
    +66
    yep i had this problem too. It turned out to be a dodgy scart lead.
